NXLOG running but no logs
NXLOG is running but not sending logs. What might be the problem?
DoubleDoubleA
Re: NXLOG running but no logs
Hi Al,
What makes you say it is not sending? Is it not sending or is Nagios Log Server not receiving? Or is nxlog sending, and NLS is receiving, but you are not finding the results in your query?
What does your nxlog.conf look like? Does the destination IP match your actual Log Server IP? What query are you running to find the logs?
Aaron
Aaron
I'm attempting to receive Windows logs. NXlog service is running. I put the correct information into nxlog.conf file it matches and <Output out>
Module om_tcp
Host 172.16.220.129
Port 3515
is the correct destination. And I get: No logs found. No logs from that host in the database. The sender's firewall may be blocking the logs or the sender may be misconfigured.
Module om_tcp
Host 172.16.220.129
Port 3515
I also see this is NXlog Data log:
2025-01-25 12:55:58 WARNING no functional input modules!
2025-01-25 12:55:58 WARNING no routes defined!
2025-01-25 12:55:58 INFO nxlog-ce-3.2.2329 started
- jmichaelson
That looks like a misconfiguration of nxlog. Can you post the contents of nxlog.conf from c:\program files\nxlog\conf?
-Jason
-Jason
