Very slow web interface in Nagios XI
Post Reply
riahc3
Post by riahc3 »
Hello
I have 89 hosts and 966 services
The Nagios XI VM has
4 vCPUs
8GB RAM
60GB SSD
Ubuntu 24.04
Every time I click on something that goes to a new page, everything is not responsive and it takes a few seconds.
I read the improving performance article but nothing seems to do anything.
The only thing I havent done is a RAM disk: I can increase the specs of the machine but it seems a bit overboard for this.
Can anyone tell me what to check? Maybe I missed something obvious and its a easy fix.
Thank youy
danderson
Re: Very slow web interface in Nagios XI
Post by danderson »
Thanks for reaching out,
Do you know what the load on the system is? You can use a tool like htop to check this. Otherwise, maybe it's a network connection speed issue? Which theme are you using that's experiencing the slow page loads and is it different between Modern and Neptune?
riahc3
Post by riahc3 »
danderson wrote: Mon Jan 27, 2025 11:42 am Thanks for reaching out,
Load doesnt seem to be high
That being said, If I take a look at top, I do see this:
So it does seem there are things that spike the system....
How can I reduce this?
lgute
Post by lgute »
Hi @riahc3,
Thank you for providing that information. It seems odd that you have all of those php threads running.
We will do our best to help you in this forum, but you may get a faster resolution by opening up a support ticket here: https://support.nagios.com/
-Laura
Post Reply
