Hello All,
Im new here and new to this system.
Im trying to install NagiosXI on a VM with Ubuntu 24.
Can anyone help?
i did the installation with sudo , server is updated. any ideia?
i am trying to install it manually , and i got this error:
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './11-subcomponents'
+ exit 1
Log says:
Nagios XI Installation Log
DATE: Wed Jan 29 11:00:28 AM UTC 2025
DISTRO INFO:
Ubuntu
24.04
x86_64
THIS IS A NEW INSTALL!
INSTALLING:
full=2024R1.3.3
major=2024R1
minor=3.3
releasedate=2024-01-22
release=60303
Configuring Repos...
Repos configured OK
This script needs to be run as root/superuser.
DATE: Wed Jan 29 11:09:47 AM UTC 2025
DISTRO INFO:
Ubuntu
24.04
x86_64
INSTALLING:
full=2024R1.3.3
major=2024R1
minor=3.3
release=60303
Repos already configured - exiting.
Installing prerequisites...
Checking conflicting packages
dpkg-query: package 'nagios' is not installed and no information is available
dpkg-query: package 'nagios-nrpe' is not installed and no information is available
dpkg-query: package 'nagios-nsca' is not installed and no information is available
dpkg-query: package 'ndoutils' is not installed and no information is available
dpkg-query: package 'ndoutils-mysql' is not installed and no information is available
dpkg-query: package 'nrpe' is not installed and no information is available
dpkg-query: package 'nsca' is not installed and no information is available
Thank you all!
NagiosXI Installation error
Re: NagiosXI Installation error
Hi @Savan,
Thanks for reaching out. We could use a little more information, in order to help you.
How big is the downloaded file?
What command did you use to run the manual installation?
Could you please attach the complete install.log file? There should be more information about the failure towards the bottom.
-Laura
-Laura
Hello , thank you for the reply.
i started with
sudo wget --no-check-certificate https://repo.nagios.com/GPG-KEY-NAGIOS-V3
rpm --import GPG-KEY-NAGIOS-V3
then :
cd /tmp
sudo wget --no-check-certificate https://assets.nagios.com/downloads/nag ... est.tar.gz
tar xzf xi-latest.tar.gz
cd nagiosxi
sudo ./fullinstall
i have attached here the full log.
i started with
then :
cd /tmp
cd nagiosxi
sudo ./fullinstall
Hi @Savan,
I'm wondering if you're trying an offline install based on the missing packages you're seeing and the inclusion of the GPG key. Here is a link to our offline install instructions. The offline tarballs we provide should contain the dependent RPMs, so if an offline install is the goal here you'll want to use the offline tarball. Please let us know if this isn't the issue you're seeing.
Dear @jsimon
thank you for the reply, I have installed all the libraries and components one by one. and then did the installation.
Best Regards,
Savan
Best Regards,
Savan
-Laura
-Laura
TheCooDave
Just went through this. On the newest Ubuntu image, with the newest NagiosXI I would get failure. It would fail on postfix. I would use a "sudo apt purge postfix" removing postfix after failure, re-install it would work.
Needed to install an older version (2024R1.1.3, our current server can't go higher) on Ubuntu (we needed to upgrade our server), tried on the newest version of Ubuntu and POSTFIX would fail (again) and after that a "chromium" failure due to dependencies, tried to manually install the dependencies, no luck and could not get it to run. Needed to go to Ubuntu 20.04.6 (after trying 22.04.5 and complete failure) and it would install after the postfix fail. updated, then backed up, made a new Ubuntu 24.04.1 LTS vm, installed the latest NagiosXI, restored and that is how I got it to the latest NagiosXI on the latest server.
Still problems with Vmware hosts but, opened a ticket on that one...
