Good morning,
I am attempting to perform an offline install of NagiosXI using of the offline tarball method with nagiosxi-2024R1.3.3-1.el9.x86_64.tar.gz, but I have just been encountering problem after problem.
The install seems to succeed, with the "Nagios XI Installation Complete!" prompt coming up.
I do not see the offline install creating any databases or tables within the databases, none of the nagios directories under /usr/local/ are being created.
Any help you can provide is greatly appreciated.
Thank you
NagiosXI Offline Install Fails RHEL9
Re: NagiosXI Offline Install Fails RHEL9
I just installed the same. You should have the following in /usr/local/:
nagvis
bin
nsis
nrdp
nagios
nagiosxi
Did you install as root or sudo?
nagvis
bin
nsis
nrdp
nagios
nagiosxi
Hello, rlee8394
Negative on the directories. The install was ran as root.
Do you have the codeready-builder-for-rhel-9-x86_64-rpms repo enabled? You need that.
Hello, rlee8394
We do have access to all of the repos required, RHEL Base, AppStream, EPEL, and codeready-builder-for-rhel-9-x86_64-rpms, and we are using the tarball that now includes all of the dependent RPMs.
