Nagios won't create performace-data for plugin
Post Reply
johnburr
Post by johnburr »
I made a bash script for Nagios to test with Nagiosgraph. Rrd files are however not being created for this script. Default plugins that come with Nagios work well with Nagiosgraph and rrd files of those plugins are also present.
Here is the script:
#!/bin/bash
checkgpu=$( nvidia-smi --format=csv --query-gpu=utilization.gpu | awk '/[[:digit:]]+[[:space:]]%/ { tot+=$1;cnt++ } END { print tot/cnt }' | cut -d$
output="Load Average: $checkgpu"
if [ $checkgpu -ge 0 ]
then
    echo "OK- $output"
    exit 0
elif [ $checkgpu -eq 101 ]
then
    echo "WARNING- $output"
    exit 1
elif [ $checkgpu -eq 102 ]
then
    echo "CRITICAL- $output"
    exit 2
else
echo "UNKNOWN- $output"
exit 3
fi
What should i do to make this script work with Nagiosgraph/Performance data ?
Thanks in advance!
DoubleDoubleA
Re: Nagios won't create performace-data for plugin
Post by DoubleDoubleA »
Hi @johnburr,
Your plugin is not as yet written to pass performance data. Please see the docs on plugin output here https://nagios-plugins.org/doc/guidelin ... PLUGOUTPUT .
Aaron
Post Reply
