monitor the ESX / ESXi host
Post Reply
op-team
Post by op-team »
I'm running NagiosXI 2024R1.3.4 on a RedHat9.5
I have installed the required packages without issue
[root@nagios-01: ~]# pip list | egrep "setuptools|wheel"
setuptools 75.8.0
wheel 0.45.1
[root@nagios-01: ~]# rpm -q python3-pyvmomi
python3-pyvmomi-7.0.3-6.el9.noarch
But running the Vsphere Wizard, i get the error "Required software components are missing"
I'am missing something?
My python version is 3.9.21
Thank for your help
jsimon
Re: monitor the ESX / ESXi host
Post by jsimon »
Hi @op-team,
Can you post the output of the following terminal command?
python3 -m pip show pyvmomi
The wizard is looking for specific output from this command, so this will help with diagnosis. Thanks!
op-team
Post by op-team »
This is the result:
[root@nagios-01: ~]# python3 -m pip show pyvmomi
Version: 7.0.3
Summary: VMware vSphere Python SDK
Home-page: https://github.com/vmware/pyvmomi
Author: VMware, Inc.
Author-email: [email protected]
License: License :: OSI Approved :: Apache Software License
Requires: requests, six
Required-by:
op-team
Post by op-team »
Any idea?
wneville
Post by wneville »
Hello
I am also experiencing this issue. I installed pyvmomi via pip as well as yum and restarted nagios. NagiosXI version 2026R1.2
kg2857
Post by kg2857 »
You should start a new thread and describe what's going on.
nousgustaoav
Post by nousgustaoav »
This usually happens when the wizard is checking a different Python environment than the one where pyvmomi is installed.
Even though pip show looks fine, XI often uses its own Python path. Try installing it explicitly with the same interpreter XI uses, for example:
/usr/bin/python3 -m pip install pyvmomi
Then restart Nagios:
systemctl restart nagios
If it still fails, check which python the wizard is calling and make sure pyvmomi is in that exact path. This mismatch is the most common cause of that error.
bsemkoff
Post by bsemkoff »
I agree with @nousgustaoav, pyvmomi is most likely not installed in the place the wizard expects it to be. I recommend trying
pip3 install --upgrade pyvmomi
as that seems to have the most success.
If that still fails, I recommend opening a support ticket with our Technical Support team at https://support.nagios.com/.
Post Reply
