Nagios XI help menue keep dropping down
I just upgraded to latest version of nagios xi, all went well, no issues. However I'm noticing that now when I go to any page the help menu on the top right side keeps popping up. This has not happened before and it only happens with the Modern theme and Modern Dark theme. Has anyone else experienced this?
gwesterman
Re: Nagios XI help menue keep dropping down
Hi @rbnagios,
Are there are errors in the console? Any php errors? Does it happen on every browser? Does it continue to happen if you refresh the cache?
Thank you!
Thank you!
All great questions @gwesterman,
yes this was happening with different browsers and even after I cleared cache. However just clicking around, I noticed if I take the Nagios XI tour: User Profile (Top right side) --> Nagios XI tours (mid left side). When I ended the tour it didn't happen again. Not sure why this would fix it, but it's not happening anymore.
Hello @rbnagios,
This may be an issue with the tours or the tours library. I will file a bug for it and we'll check it out.
