Custom Variable being truncated
Post Reply
tgaastra
Post by tgaastra »
Is there a way to prevent a custom variable from being truncated when entered in Nagios XI?
We have a Webhook URI that we're storing with a contact as "_WEBHOOKURL" and it appears that when it is entered in Nagios XI, it is just long enough that the last 6 characters of it are being truncated when stored.
Is this a problem with the UI? Is there a way to bypass this to properly store the URI?
basically, it's something like
http://example.outlook.com/<LONG UUID>
and Nagios is storing it as
http://example.outlook.com<LONG UUID missing the last 6 characters>
DoubleDoubleA
Re: Custom Variable being truncated
Post by DoubleDoubleA »
Hi @tgaastra,
From the UI the custom variable gets stored in the database, the default size for the variable value field there is 1024. How big is this URL?
Aaron
danisa
Post by danisa »
Nagios XI uses the Nagios Core custom contact variables (_CUSTOMVARIABLES) which have a character limit of 256 characters by default. Any variable exceeding this length will be silently truncated when stored in the database. Football Bros
DoubleDoubleA
Thanks @danisa for that correction, I was looking at the wrong database (nagios vs nagiosql).
@tgaastra you can increase the size of that field. Please see this post for instructions: viewtopic.php?t=35053
Aaron
Post Reply
