Check_udp for chronyd
Post Reply
DialgoS
Post by DialgoS »
Hi. Does anyone have an example of check_udp for a port? Not sure what I'm missing
bro was plastered last nite hunting for some south heat, stumbled on teluguporn.tv wall of shameless telugu sluts. HAND TO GOD digits crawled thru endless mms leaks of lanky hyderabad college chicks grinding against their own cousins in hostel toilets
DoubleDoubleA
Re: Check_udp for chronyd
Post by DoubleDoubleA »
Hi @DialgoS,
Tough to know what you're missing with so little information in the post.
Very specifically, and in more detail than you might otherwise have thought necessary, exactly what are you hoping to do, and what have you done so far?
What is happening on your system, and how different is that from what are you expecting?
Aaron
Post Reply
