NagiosXI - Perf Graph No data to display Upgrade 1.1.4 to 1.4.1
Post Reply
vdrnagiosml
Post by vdrnagiosml »
I recently upgrade from 1.1.4 to 1.4.1, I downloaded the lastest OVA from Nagios, deployed the VM, exported my 1.1.4 backup to the new VM, restored it, than upgrade to 1.4.1 and everything seems to be ok. The only problem I see is the Perf Graph not displaying anyone, no data to display. Tried few things but still no go. Need help of this. Thanks
bbahn
Re: NagiosXI - Perf Graph No data to display Upgrade 1.1.4 to 1.4.1
Post by bbahn »
Hello @vdrnagiosml,
We are aware of this issue and I believe it should be resolved in the 1.4.2 release if it is the bug I'm thinking it is.
kfanselow
Post by kfanselow »
Hi vdrnagiosml,
The restore process is intended to be done on a system running the same version of XI as the source machine ( in your case 1.1.4 ). The quickest thing to do might be to build a fresh Linux image rather than use the ova image, install the same version of XI it and then perform the restore following the instructions in our backup and restore document ( note the different OS section near the end ):
For convenience here is our previous version archive and a link to our supported OS matrix
https://assets.nagios.com/downloads/nag ... rsions.php
https://support.nagios.com/kb/article/n ... -1045.html
If you want to try to getting your current ova image probably the easiest way to resolve the problem would be to open a support case so they can look at the state of your system via a diagnostic profile.
Thanks and best of luck with your migration !!
titien104
Post by titien104 »
Hi Team,
I have similar issue with the performing graph just now showing but we do get alert as normal.
Here is our system profile:
Nagios XI - System Info
System
Nagios XI version: 2024R1.4.1
Release info: 1365pl-nagios02 4.18.0-553.47.1.el8_10.x86_64 x86_64
Red Hat Enterprise Linux release 8.10 (Ootpa)
Gnome is not installed
Apache Information
PHP Version: 7.2.24
Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36
Server Name: nagiosxi.medecision.com
Server Address: 172.19.152.114
Server Port: 443
Date/Time
PHP Timezone: US/Central
PHP Time: Mon, 05 May 2025 13:55:18 -0500
System Time: Mon, 05 May 2025 13:55:18 -0500
seaward1983
Post by seaward1983 »
Is there an ETA on deliver of the 1.4.2? We're experiencing the same issue. Alerting/notification fine, no perf graphs on any services.
Post Reply
