Is Nagios is for developer only?
Post Reply
ShanonHeller
Post by ShanonHeller »
I just installed Nagios XI and tried to monitor some Forti firewalls and Cisco switches, but I found that maybe I need to root SSH into the box and install some third-party GitHub plugins.
I tried another opensource product, I only need to tell my firewall IP address and snmp community string then it will show me everything including CPU, memory, traffic loads, fans speed, HA, VPN, etc.
Now after fighting with nagios for a few hours I still can't figure out how I can monitor just one fortigate firewall and feel pretty helpless.
I think nagios is much more famous so I really like learn about it. Any hints how I can add my devices easily without googling hours for plugins?
sgardil
Re: Is Nagios is for developer only?
Post by sgardil »
ShanonHeller wrote: Thu Mar 13, 2025 8:44 pm I just installed Nagios XI and tried to monitor some Forti firewalls and Cisco switches, but I found that maybe I need to root SSH into the box and install some third-party GitHub plugins.
Hey @ShanonHeller
When you were attempting to monitor the firewall and switches, were you using our wizards to do so? Our switch/router wizard allows you to monitor using snmp as well so you wouldnt need to ssh in. You can also use our snmp wizard to monitor devices that way, I believe this is the way you would want to go for monitoring your firewall. While Nagios does allow you to make your own plugins and do your own modifications, you shouldn't need to for most things you want to monitor. Let us know if this helps or if you have anymore questions.
danisa
Post by danisa »
Nagios relies on plugins for almost everything, and the base install doesn't auto-discover or template SNMP devices like some alternatives. But once you get used to the modularity, it’s very flexible.
Sprunki Incredibox
bbahn
Post by bbahn »
@danisa, Nagios XI actually does have an autodiscovery feature. It doesn't run automatically, however and must be run by the user and they must then select what they want to monitor from among the found devices.
florencepugh
Post by florencepugh »
Hi Shanon,
Nagios is not just for developers but requires technical setup, including plugins and configuration,Crazy Cattle 3D which can be challenging for beginners. To monitor devices like FortiGate firewalls easily in Nagios XI, use pre-built plugins from the Nagios Exchange or wizards to simplify setup without extensive coding or plugin hunting.
nagios-dnelson
Post by nagios-dnelson »
@ShanonHeller ~
After a few months now, I'm curious if you ended up using Nagios for your monitoring solution. If you did, what do you like about it? What can be done better?
-Doug
shali012
Post by shali012 »
nagios-dnelson wrote: Wed Sep 03, 2025 10:26 am @ShanonHeller ~
mp bhulekh
-Doug
Hi Doug,
Yes, we ended up using Nagios for our monitoring solution. What I like most is its flexibility and extensive plugin support, which makes it easy to monitor a wide range of systems. However, the interface can feel outdated, and initial setup requires careful configuration.
nagios-dnelson
shali012 wrote: Sat Sep 13, 2025 10:25 am
mp bhulekh
-Doug
Hi Doug,
Have you tried switching your theme? I recommend using the Neptune theme!
Neptune feels a lot more up to date, and I think you'll like it!
Here is a quick video showing you how to do that:
https://www.youtube.com/watch?v=OSk8iSgLEYU
-Doug
Post Reply
