Ghost config
matson-itops
Ghost config
Post by matson-itops »
Getting error below :
Error: Could not find any host matching 'EQX1VWPD05 - WMS Database Server' (config file '/usr/local/nagios/etc/services/EQX1VWPD05 - WMS Database Server.cfg', starting on line 127)
this file and host does not exist anymore. How can I clear it? it is preventing me from applying configuration.
DoubleDoubleA
Re: Ghost config
Post by DoubleDoubleA »
Delete the service first in the CCM, then the host.
In order to delete a host, we have to remove all of the dependencies on it.
matson-itops
Re: Ghost config
Hi
Not sure in what order I did the deletes.
I was able to delete services and host. I no longer see the services, hosts, or raw config file
referenced in the error.
But still no luck applying configuration.
jmichaelson
Re: Ghost config
Post by jmichaelson »
Can you go back to the last known good configuration snapshot and re-attempt your deletes?
-Jason
matson-itops
Re: Ghost config
Went back to oldest config we have and still same error.
DoubleDoubleA
Re: Ghost config
matson-itops
Re: Ghost config
No errors, but still unable to "apply config"
I also confirmed config files were re-written.
Is there anywhere else this "bad config" could still be hiding?
Re: Ghost config
Take a look in this directory for a configuration file
/usr/local/nagios/etc/import/
If you see a file in there, that could be what is creating the configuration error so delete the file.
Re-run the Delete, Write, Delete, Verify process from the KB article again and if the verify works, try and apply the configuration.
[email protected]
Re: Ghost config
Post by [email protected] »
using different account . matson-itops / [email protected].
I do find the host under /usr/local/nagios/etc/hosts
I keeps showing back up after a delete/write. I suspect this config is somehow in DB or cached somewhere.
gwesterman
Re: Ghost config
Post by gwesterman »
You can try repairing the database if you haven't already.
./repair_databases.sh
service nagios stop
service ndo2db restart
service nagios start
Post Reply
