API config host - how to configure hostgroup inheritance
hostgroupguy
Post by hostgroupguy »
I'm using Nagios XI API to configure my hosts. I'm able to do it successfully except for hostgroup inheritance.
The options for choosing hostgroup inheritance for host in the GUI are standard, null or +.
In my code I'm posting hostgroups like this:
$hostgroup="+hostgroup1,hostgroup2"
curl -X POST "$ENDPOINT" -d "hostgroups=$hostgroups"
It seems that nagios deletes the + all together cause in the GUI option standard is selected?
Thanks for your help.
DoubleDoubleA
Re: API config host - how to configure hostgroup inheritance
Post by DoubleDoubleA »
It might be that the + is being interpreted as a space due to url encoding.
try:
$hostgroup="%2Bhostgroup1,hostgroup2"
hostgroupguy
That was the case indeed.
Thank you!
