nagiosxi status is not updating compared to nagios-core
story
Post by story »
we have a situation where nagios xi status does not match nagios-core status. What is the best way to resolve this?
- We have rebooted the server
- Verified that nagios core is responding to "force immediate check"
- did the repair database script
im assuming the DB is connected since we are seeing nagiosxi web page, but is there another db connection we need to verify?
jsimon
Re: nagiosxi status is not updating compared to nagios-core
Post by jsimon »
Hi @story,
It does sound like there is an issue with your Nagios XI database. What version of Nagios XI are you running? We added a script in version 2024R1.2.2 called "repair_crashed_databases.sh", which may fix this issue for you. You can find the script here, if you're on version 2024R1.2.2 or higher:
/usr/local/nagiosxi/scripts/repair_crashed_databases.sh
Let us know if you're on an older version and I'll work on getting you a version of this that you can run locally.
story
Post by story »
we are version 1.1.2.
story
Post by story »
we are looking to upgrade but our change management process can be difficult. Doing this repair with the script, we can do as an emergency.
if the script would be ok for my version, I can extract it from the newer update package...
thanks.
story
Post by story »
the /usr/local/nagios/etc/ndo.cfg file had bogus characters in it. restored it from backup...
we did a MD5SUM on every file from a backup against all the files in the current filesystem, this was one that came back different...
dunno why it was able to read and we got no errors on mysql updates or reads. (we monitored for mysql connection failures and query failures in the logs.. didnt see any..)
jsimon
Post by jsimon »
Hi @story,
I believe you should be okay to extract the script from a newer tarball and run it locally to repair your databases. I'd advise backing up your system before doing this generally, however from your most recent post it sounds like you were able to solve your issue. Please let me know if you have any other questions or issues, otherwise I'll go ahead and lock this topic.
