Are there files that are safe to delete?
Post Reply
Pichme
Post by Pichme »
When my root partition gets full, which it does frequently, are there files that are safe to delete?
jsimon
Re: Are there files that are safe to delete?
Post by jsimon »
Hi @Pichme,
We have an article with guidance that may be helpful for your situation:
https://support.nagios.com/kb/article.php?id=26
The short answer is that you are likely okay to delete old snapshots, database backups, and logs. You can remove these from your system or migrate them to another system for storage if you need to keep them but don't have space on your Nagios XI server. Please let us know if you have any questions about this, or if this doesn't resolve your issue.
Post Reply
