Good Afternoon,
What happened to the "Help" section that had the API docs? Where can that information be found in this new version?
Maxwell Ramirez
New install of Nagios XI 2024R1.4.1
DoubleDoubleA
Re: New install of Nagios XI 2024R1.4.1
In the Neptune theme there is the ? icon on the left sidebar that will take you to the help section, and that includes the API docs. You can also get there directly with http://<your.xi.ip.addr>/nagiosxi/help/, and also in Neptune you can type api into the search bar and click on the appropriate link below to get to the docs.
