Automated Report Not Sending
Post Reply
gregbeyer
Post by gregbeyer »
I have Top Alert Producers as a scheduled report, however I'm not getting it and according to the scheduled report history, it is not sending either. If I trigger manual run and send, it sends. Suggestion to solve?
jsimon
Re: Automated Report Not Sending
Post by jsimon »
Hi Greg,
What version of XI are you running right now? Do you have any other scheduled reports? It would be good to know if it's an issue with just this report, or all scheduled reports vs reports generated on demand.
Can you take a look at this log to see if there are errors?
/usr/local/nagiosxi/var/chromium_report.log
gregbeyer
Post by gregbeyer »
Running XI 2024R1.3. This is the only scheduled report I run.
Yes, I have a lot of these:
/usr/bin/chromium-browser: error while loading shared libraries: libvmaf.so.1: cannot open shared object file: No such file or directory
[Thu, 10 Apr 2025 08:41:11 -0400] chromium-browser --headless=new --ignore-certificate-errors --enable-low-end-device-mode --disable-gpu --virtual-time-budget=10000 --run-all-compositor-stages-before-draw --no-pdf-header-footer --desktop-window-1080p --print-to-pdf='/home/nagios/topalertproducers-67f7bc66e77bb.pdf' 'https://localhost/nagiosxi/reports/topa ... 1&export=1'
gregbeyer
Post by gregbeyer »
bump
vedicsystems
Post by vedicsystems »
Missing libvmaf.so.1 is your culprit, report rendering via Chromium is failing before it can even start.
Post Reply
