NSClient : does exist an alternative solution
Post Reply
emi65
Post by emi65 »
Hi
I'm using Nagios and NSClient++
Does it exist an alternative SW solution ?
Can I use another solution instead of NSClient++
thanks
Emilio
MaterazziSan
Re: NSClient : does exist an alternative solution
Post by MaterazziSan »
You have an agent comparisson https://assets.nagios.com/downloads/ncp ... arison.pdf
Best regards
bbahn
Post by bbahn »
Hello @emi65,
There is a great alternative to NSClient that is actually the recommended agent to use with Nagios: NCPA! The Nagios Cross-Platform Agent will monitor everything you need and can run plugins that you've configured on that system if needed. As can be seen in the agent comparison linked by MaterazziSan, NCPA handles all your monitoring needs.
Post Reply
