Failed install, brand new RHLE, 2024R1.0.1
theo481
Post by theo481 »
Log attached.
Getting a failed install. Seems to be happening at the end of the install.
Base class package "Class::Accessor::Fast" is empty.
    (Perhaps you need to 'use' the module which defines that package first,
    or make that module available in @INC (@INC contains: lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/lib /tmp/nagiosxi/subcomponents/extraplugins/Nagios-Monitoring-Plugin-0.51/blib/arch /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .).
 at lib/Nagios/Monitoring/Plugin.pm line 11.
BEGIN failed--compilation aborted at lib/Nagios/Monitoring/Plugin.pm line 11.
Compilation failed in require at t/check_stuff.pl line 19.
BEGIN failed--compilation aborted at t/check_stuff.pl line 19.
jsimon
Re: Failed install, brand new RHLE, 2024R1.0.1
Post by jsimon »
Hi @theo481,
It looks like you opened a case for this issue. Our support department will reach out to you for further resolution of this issue, so I'm going to go ahead and lock this topic.
