Hello, I am a novice with Nagios Core so please go easy! I have been searching for topics and can see people are having the same physical memory usage errors that I am seeing. The Nagios server is running Fedora and ALL the clients are running a mix of Win 10 and Win 11 (unfortunately!). I am seeing incorrect memory (RAM) reporting. Memory use many times is much higher than the actual RAM usage. The network runs behind a DMVPN which is fine. I am trying to determine WHERE I add some of the statements, that I have seen posted that force the reporting of physical .vs total memory. Is this on the Nagios side or is it on the Windows side. I've looked at configurations on both the Nagios server as well as the WIndows machines and just cannot match up with what I am reading in other posts here. Again, I am really a novice at this and really and pretty happy I have gotten things to work as I have. It has been a really interesting project and I've been learning more and more as I go! Any help or guidance would be greatly appreciated!
Alan
NS Client ++ and Memory Usage error
- MaterazziSan
Re: NS Client ++ and Memory Usage error
Have you tried NCPA agent?
Best regards
Best regards
No, but I will certainly look into this. I appreciate it!
