Reports data
Post Reply
BanditBBS
Reports data
Post by BanditBBS »
Where does the availability report get its data? I thought it would be from the database of ndo database where I am keeping state history for 100 days, but it seems to be coming from /usr/local/nagios/var/archives/.
I ask, as I have a cron that deleted logs from that folder as needed as it is a very chatty XI server and it uses a crazy amount of space.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
lgute
Re: Reports data
Post by lgute »
Hi @BanditBBS,
Thanks for reaching out.
I'll have to do a bit of digging, to determine where the data comes from.
-Laura
lgute
Re: Reports data
Post by lgute »
Hi @BanditBBS,
Currently the data for the Availability report comes from both the /usr/local/nagios/var/nagios.log file and the log files in /usr/local/nagios/var/archives.
If there are database issues, the log files can grow too fast. To be safe, please run the following in a terminal session on your XI server.
grep -r INSERT /usr/local/nagios/var
If you find matches, run the database repair script.
/usr/local/nagiosxi/scripts/repair_databases.sh
-Laura
Knotnint
Re: Reports data
Post by Knotnint »
If your cron job is deleting those archive logs, that would definitely explain why your availability reports might be incomplete or missing data for the periods where the logs have been purged.
Post Reply
