Offline Documentation
Post Reply
AngeloMileto
Post by AngeloMileto »
Is there a way to download the Documentation Guides from Nagios for an offline installation and then edit the html to point to the local copy?
URL for current guides:
https://assets.nagios.com/downloads/nag ... inistrator
sgardil
Re: Offline Documentation
Post by sgardil »
AngeloMileto wrote: Thu May 08, 2025 7:37 am Is there a way to download the Documentation Guides from Nagios for an offline installation and then edit the html to point to the local copy?
Do you want all of the NagiosXI admin guides? Many of the pages on there have links to other pdf's and guides so they may not be the best resource for downloading a guide. You could modify the html in the browser and print them out manually but that sounds very tedious and not worth the time. Our pdf's may be a better source of things to download and alter as they would be easier to modify if you wanted. Do you have any specific guides you would like that I could help you find? Also are you looking for specific versions for documentation, i.e 2024 or xi 5 versions?
Mikasa23
Post by Mikasa23 »
https://assets.nagios.com/downloads/nag ... inistrator Wacky Flip
Have you tried using tools like wget --mirror or HTTrack to download the entire site? I'm curious if the Nagios document structure is easy to edit internal paths, or if there are other difficulties.
Post Reply
