I gather some most anoying bugs in 2024R2.0.1 nagios syslog server. Some of them has been mentioned there: viewtopic.php?t=76252, but i want to add some more info.
Dashboard:
1. You cannot add "description" for search same like old nagiosLS:
2. You cannot create "advanced" filter:
3. in create filters menu, if you want find "event.id" as exapmle, you got this:
instead of this:
4. Icon for filtering in Histogram sometimes showing outside the view:
5. If you make a change in search, you must hit "ENTER", every time, if you don't, the changes are not provide.
If you save and load the dashboard,without "ENTER" hits, the changes are not saved and rolled back.
6. FIXED - its not possible set columns order of table.
7. UPDATED - When Non-admin user open public dashboard, after few seconds page refresh to blank. Tested on two accounts.
After change rights to administrator, page works properly.
System:
8. I tried import data from 2024R1.3.1,import hang without any error information.
I tried restart process many times, close and open indexes on source server with same result.
9. UPDATED - Some of password txt dialogs make text visible. (Add domain user as example)
10. If you fill in proxy server and use HTTP tunel, most part of web gui stop working, because proxy exception for localhost and 127.0.0.1 is missing. I will appreciate, if text box for exceptions, will be added.
11. System status card have problem with SSL, monitor NCPA card, have problem with ssl.
[ SSL: no alternative certificate subject name matches target host name '10.X.X.X' ]
I can solve with ad SAN to certificate, but someone with DHCP address, could have problem.
12. If you want to use two factor, please use https://github.com/dochne/google-authenticator, instead of e-mail.
If you want to investigate some disaster, the e-mail could be dead. After that the logserver could be useless.
13. In some cases, if you edit "Global Config" > Input, filters, output, you can fail like this:
1. the configuration check is good, but restart of services failed.
2. the check is good, restart is success, but all listening ports disappear. You can see in log file, the service is running but listening port bindings got error.
If i find something new, i will try to update this topic
Best Regards.
