added host in host group but not see
Post Reply
vtcedu
Post by vtcedu »
I use CCM > Bulk modification > Host group > Add Host Group(S) and add some hosts to host group but the ( CCM > Host groups > open the host group) the Assign Memberships result is 0.
cnorell
Developer
Re: added host in host group but not see
Post by cnorell »
vtcedu,
A few of things come to mind. First, what version of XI are you using? Other questions:
1. Did you click "Apply Configuration"?
2. If you click "Manage Hosts" in the Host Group, do you see the added hosts in the left box in the popup grayed out with a link icon? If so, this is because the relationships are being defined and managed by the Bulk Modifications component.
3. Do you have an active Enterprise entitlement?
On point number two, if that is the case, I think we could improve the user experience here to be clearer.
Best Regards,
Cory Norell
kg2857
Post by kg2857 »
Have a look at one of the hosts and see if the hostgroup is attached.
vtcedu
Post by vtcedu »
cnorell wrote: Tue May 13, 2025 3:33 pm vtcedu,
Yes, applied
I see the host but the color is grey and I can't add it to host group.
Yes.
Best Regards,
Cory Norell
Post Reply
