Issue with nagios GUI
Post Reply
doylehinojosa
Post by doylehinojosa »
I keep getting the same error message. I have tried several different methods, and nothing seems to work. The message on the nagios GUI is:
" Error: Could not stat() command file '/usr/local/nagios/var/rw/nagios.cmd'!"
This happens every time I try to do something such as send a customer service notification. Does anyone have any advice as to how to fix this?
lgute
Re: Issue with nagios GUI
Post by lgute »
Hi @doylehinojosa,
Thanks for reaching out.
Check if the nagios user is a member of the nagios and nagcmd.
groups nagios
If the output looks like this, the groups assignment should be ok.
nagios : nagios nagcmd
If one or both groups are missing, run this command.
usermod -a -G nagcmd nagios
If these suggestions do not help, this thread has some other triage steps.
-Laura
Post Reply
