Nagios XI R2 (Premium)
Post Reply
shoreypu
Post by shoreypu »
In the 2024R1.4.2 Release communication, it says "This is the last R1.X version before the transition to XI R2 (Nagios XI Premium)".
What is Nagios XI Premium?
Thanks...John
sgardil
Re: Nagios XI R2 (Premium)
Post by sgardil »
shoreypu wrote: Fri May 16, 2025 8:31 am In the 2024R1.4.2 Release communication, it says "This is the last R1.X version before the transition to XI R2 (Nagios XI Premium)".
Thanks...John
Hey John,
Things are open to change but as it currently stands for R2 there will be the addition of premium features that are enabled while you have active support and maintenance.
gregbeyer
Post by gregbeyer »
Where are "Release communications" and how does one get them? The only place I've seen info on releases is at https://www.nagios.com/changelog/ And I have to check there manually periodically.
Post Reply
