I have created a new Nagios Core server on Almalinux 9.
I have downloaded and installed 4.5.9 with the latest 2.4.11 plugins.
All work fine except for the CHECK_DNS plugin which returns
check_dns: error while loading shared libraries: libssl.so.1.1: cannot open shared object file:
Almalinux has OpenSSL 3.2.2 4 Jun 2024 installed so a much later version.
What is the solution please?
It seems the plugin is out of date? Am I able to obtain a newer version?
Any help much appreciated.
Colin
Check_DNS failing on Almalinux 9
Re: Check_DNS failing on Almalinux 9
Update openssl.
I'm running 3.2.2.4 and it is looking for 1.1 ... how will updating openssl help?
It's running the latest version.
Sorry, my bad reading comprehension is showing.
- MaterazziSan
You can execute for having more details about that shared library.
Which output are you getting?
Best regards
You can execute
ldd $(which openssl)Which output are you getting?
Best regards
Thanks.MaterazziSan wrote: ↑Thu May 29, 2025 6:45 pm Hi,
You can executefor having more details about that shared library.Code: Select all
Best regards
Getting this OpenSSL 3.2.2 4 Jun 2024 but gave up and have now reloaded with Almalinux 8 and all up and running.
