Dashlet enhancement request
Post Reply
DBAFOX
Post by DBAFOX »
Hi
I generally love the dashlets BBMap & Minemap --
One part that is limiting that it only allows the # of service checks do to expand horizontally (ie: the dashlet gets wider)
it would be great if there was an option to change the orientation 90° clockwise
This way it would be easier to vertically scan the list of checks (vertically) vs the servers (which would then be the top columns )
something like this.
though the services could be listed on the left -- i just simply rotated the screenshot to help you visualize what I mean .
Thank you for your consideration
sincerely,
dFox
lgute
Re: Dashlet enhancement request
Post by lgute »
Hi @DBAFOX,
Thanks for reaching out.
We have an issue in our tracking system for this request and it is currently under consideration. The Changelog will include the tag [GL:XI#1771] in the Changelog if/when this is addressed.
-Laura
Post Reply
