Api Create user issue
Post Reply
btayl
Post by btayl »
I want to set "can access monitoring engine" and also I want to set "Host Notifications Enabled" set to off also "Service Notifications Enabled" set to off
I have tired
-d "can_access_monitoring_engine=1" \
-d "host_notifications_enabled=0" \
-d "service_notifications_enabled=0" \
ravagerhost
Re: Api Create user issue
Post by ravagerhost »
I have the same question about how to correctly set these options, because just using these flags may not work depending on the system’s configuration or API.
bbahn
Post by bbahn »
Hello @btayl,
You can find the following reference in the Nagios XI API help documentation under API Docs->System Reference->:POST: system/user
Post Reply
