Custom logos for hosts
Post Reply
dslaughter
Post by dslaughter »
I'm trying to add a custom png to the host. I created the logo exactly like the snmppenguin.png. I add it to the host config, misc settings in status image and icon image. It originally had the snmppenguin.png and it displays correctly. Most of the logos have a gd2,gif, and a png. snmppenguin.png only has a png. I thought I could create an image the same size, copy it to /usr/local/nagios/share/images/logos and it would load. It doesn't, there is just a blank space where it should be in the host list.
snmppenguin.png: PNG image data, 40 x 40, 8-bit/color RGBA, non-interlaced
Rocky_Linux_Logo.png: PNG image data, 40 x 40, 8-bit/color RGBA, non-interlaced
Am I missing a step somewhere?
dslaughter
Re: Custom logos for hosts
I have xi and hadn't copied it to the correct directory. It should be here /usr/local/nagiosxi/html/includes/components/nagioscore/ui/images/logos/
Problem solved
Post Reply
