We a server we recently updated to 2024R1.4.3 and since then, every time I try to add a new host or make a modification to a host using the GUI I get an error message saying "Missing required fields" and trough trial and error I realized that is complaining that the filed "Max check attempts" is not set.
We have never set the field Max check attempts on any hosts as we define that value on a host template than latter is assigned to our hosts. Now NagiosXI makes it compulsory to defined the field "Max check attempts" on every single host or is this a bug?
This only happens when I try to make the change trough the GUI because If I upload a .cfg into the import folder it will work OK. I have not tested yet if it works trough the API.
Also I realized the filed "Max check attempts" no longer have a * symbol next to it.
Nagios 2024R1.4.3 possible bug Max check attempts field
Re: Nagios 2024R1.4.3 possible bug Max check attempts field
This issue will be resolved in 2024R1.4.4, which will be releasing shortly. Thank you for your patience.
Thanks for this. I was encountering the same issue and the work round has been implemented.
Thank you!!!kg2857 wrote: ↑Thu Jun 05, 2025 6:02 am Have a look here.
viewtopic.php?p=361538&hilit=max+check+attempts#p361538
