kernel panic with .ova
Post Reply
alainbron
Post by alainbron »
The .ova file downloaded (juny 2025) for vmware ESXi run in panic kernel at the boot time.
I'm using ESXi 7.0.u3
Any workaround ?
run74909
Re: kernel panic with .ova
Post by run74909 »
If you can capture the exact panic message, it can help narrow down whether it’s:
Missing CPU feature (like SSE4 or AES-NI)
Incompatible initrd/kernel drivers
Filesystem not mounting
fnaf 1
Send me a screenshot or the panic message if you'd like me to help decode it.
Mikasa23
Post by Mikasa23 »
alainbron wrote: Fri Jun 06, 2025 10:25 am Hello,
I'm using ESXi 7.0.u3 Slope Game
Any workaround ?
Hey Alain, I’ve seen this happen when the OVA’s kernel doesn’t play nice with the ESXi version. You can try setting the right Linux OS type in the VM settings and, if that fails, repackage the OVA with a newer hardware version using ovftool.
Post Reply
