Nagios restart problem after windows.cfg modification
deesdabeth
Post by deesdabeth »
Hi everyone,
I've modify the /etc/nagios/objetcs/windows.cfg file and now when I try to restart nagios it says :
[root@nagios nagios]# nagios restart
Nagios 3.0.6
Copyright (c) 1999-2008 Ethan Galstad (http://www.nagios.org)
Last Modified: 12-01-2008
License: GPL
Error: Cannot open main configuration file '/etc/nagios/restart' for reading!
Nagios 3.0.6 starting... (PID=11434)
Local time is Thu Oct 04 08:52:01 CEST 2012
Bailing out due to one or more errors encountered in the configuration files. Run Nagios from the command line with the -v option to verify your config before restarting. (PID=11434)
And then if i do a nagios -v nagios.cfg it says everything seems to be ok :
[root@nagios nagios]# nagios -v nagios.cfg
Nagios 3.0.6
License: GPL
Reading configuration data...
Checking services...
Checked 39 services.
Checking hosts...
Warning: Host 'FAXSERVER' has no services associated with it!
Warning: Host 'SRVI' has no services associated with it!
Warning: Host 'SRVP' has no services associated with it!
Warning: Host 'SRVTSE' has no services associated with it!
Warning: Host 'SRVTSE2K3' has no services associated with it!
Warning: Host 'SRVTSE3' has no services associated with it!
Checked 15 hosts.
Checking host groups...
Checked 3 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 1 contacts.
Checking contact groups...
Checked 1 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 24 commands.
Checking time periods...
Checked 5 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 6
Total Errors: 0
Can someone help me to find the problem?
agriffin
Re: Nagios restart problem after windows.cfg modification
Post by agriffin »
Try running 'service nagios restart' instead of just 'nagios restart'.
deesdabeth
It works!
Thank you very much
deesdabeth
But now I have a access right problem on this new server :
***** Nagios *****
Notification Type: PROBLEM
Service: C:\ Drive Space
Host: Serveur Paie CEGID
Address: 192.168.0.2
State: CRITICAL
Date/Time: Fri Oct 5 13:47:48 CEST 2012
Additional Info:
Connection refused
Where does it came from?
agriffin
Post by agriffin »
What are you using to check services on that host? NSClient++ (and if so, is it using NRPE)? WMI?
