AIX Monitoring with Nagios
Post Reply
SorinRaduD
Post by SorinRaduD »
Is there a monitoring solution with Nagios for AIX 7.1, 7.2 and 7.3 LPARs on IBM Power10 servers ?
Thank you !
Best regards,
Sorin-Radu Dumitrascu
kg2857
Re: AIX Monitoring with Nagios
Post by kg2857 »
Nagios is pretty generic and will monitor anything you can tell it (AIX in this case) to, or have send status info from.
SorinRaduD
Thank you for the response !
Could you please be more specific, is there a procedure for configuring AIX 7.1, 7.2 and 7.3 servers for monitoring with Nagios ?
Thank you !
MaterazziSan
Post by MaterazziSan »
Not sure if you have some agent available, maybe you need to check SNMP protocol.
Best regards
SorinRaduD
Thank you very much for the response !
I'll check the Nagios monitoring for AIX LPARs 7.1, 7.2 and 7.3, on IBM P10 servers, by using SNMP protocol in Nagios XI 2024 => https://assets.nagios.com/downloads/nag ... P-2024.pdf
Post Reply
