httpd upgrade
Post Reply
matson-itops
httpd upgrade
Post by matson-itops »
running latest nagios 2024R1.4.1
need to update httpd for security.
is there some doc we can follow for best practices?
goal is to ensure we have a proper backup of ALL relevant config files.
our install is default with doc root at /var/ww/html and some configs under /etc/httpd/conf.d
but need to verify all config files are here and nowhere else.
matson-itops
Re: httpd upgrade
No responses? is there a doc on httpd configs required?
DoubleDoubleA
Re: httpd upgrade
Post by DoubleDoubleA »
What version of Apache are you on, and what version would you like to get to? Generally Nagios does not specify an Apache version, and runs with whatever the version the OS installs. What OS and OS version are you on?
Post Reply
