NagiosXI Azure SSO no clear error
Post Reply
ydufraisse
Post by ydufraisse »
I'm trying to make the new external sso feature work, and it seems very easy ... But I have 3 nagios, and have the same behaviour on each one of them.
Just "An error occured. Please try again". Where are the log located ? I can't find them.
Regards,
SprunkiRetake
Re: NagiosXI Azure SSO no clear error
Post by SprunkiRetake »
Ugh, “An error occurred. Please try again” is the worst! Okay, don’t panic, the key is finding those logs. Usually, Nagios logs are hiding in /var/log/nagios/, but if not, check your Nagios configuration file for the log_file directive – that’ll tell you exactly where to look!
Sprunki Retake Good tunes will help people relax!
Post Reply
