I would like to know if there is a REST API to allow changes to the method of backup used for the nagios system.
This would be under: /nagiosxi/admin/
I need to change the password that is used for backup across multiple instances and would like to script it.
Scott
Admin Backup REST API
Re: Admin Backup REST API
-Laura
-Laura
Hi Scott,
There is not currently a way to use the REST API to configure the Admin Backup. However, you might be able to accomplish this by writing a custom endpoint for the REST API or using a tool like Ansible.
The documentation for writing custom API endpoints is not publicly available, but can be found in your Nagios XI web interface along the following path: http://<XI.Server.IP>/nagiosxi/help/ under Developer Docs -> Custom API Endpoints.
I will also include a link to a guide that shows some examples of what the REST API can do.
https://library.nagios.com/techtips/har ... -rest-api/
Cheers,
- Cole
- Cole
