NCPA 3.2.0 Shared Libraries Failure
Post Reply
sawdusty
Post by sawdusty »
I installed the new NCPA 3.2.0 on one of my Ubuntu servers to see how it worked. When I restarted the service and making my ncpa.cfg configuration changes, the service failed to start up. It provided the following 'error while loading shared libraries: libcrypt-adfd3357.so.2: cannot open shared object file: No such file or directory' Is there an update that I'm missing? I'm running an offline system (Nagios XI 2024R1.4.2).
bbahn
Re: NCPA 3.2.0 Shared Libraries Failure
Post by bbahn »
Hello @sawdusty,
Can you tell us what version of Ubuntu you encountered this on? There was a similar issue that arose from one of our early 3.2.0 builds, but we didn't encounter that issue after re-building the package. Did you install NCPA from the .deb package or via the RPM or did you build it yourself?
bbahn
Post by bbahn »
@sawdusty,
It looks like the wrong DEB build got uploaded. The RPM is currently good and we will be uploading the correct DEB package shortly.
sawdusty
Post by sawdusty »
I've installed this on an Ubuntu 22.04 server. I installed the deb file manually.
sawdusty
Post by sawdusty »
bbahn wrote: Fri Aug 22, 2025 11:27 am @sawdusty,
@bbahn
Let me know when the correct file is available for download. Thanks
bbahn
Post by bbahn »
The file was fixed on Friday, so you're good to re-download it!
Post Reply
