check_postgres.pl sequence error on d.adsrc
Post Reply
CBoekhuis
Post by CBoekhuis »
After update from 2024R2 to 2024R2.1 also the check_postgres.pl plugin is updated. However this pluging throughs an error related to the postgres DB version (ERROR: column d.adsrc does not exist) . The installed version 2.21 of the plugin does not work correctly when checking the sequence on pg version 15. Version 2.26 of the plugin does. It would be nice that newer version will be deployed on upgrade or installation of nagiosxi.
Since postgres12 the adscr colomn is deprecated and also postgres12.22 is not supported anymore.
Regards,
Christian
kg2857
Re: check_postgres.pl sequence error on d.adsrc
Post by kg2857 »
You probably want to convert Postgres to Mysql since nagios stopped using it on new installs about a dozen releases and several years ago...
CBoekhuis
Post by CBoekhuis »
The plugin used to monitor other postgres databases. Of course nagiosxi itself runs on mysql. But de plugin that is used also to monitor other DB's that is installed is outdated.
kg2857
Post by kg2857 »
Sorry I misunderstood...
jsimon
Post by jsimon »
Hi Christian,
Thanks for reaching out! I've created an internal issue to update this plugin.
CBoekhuis
Post by CBoekhuis »
almost an year later, but every update/upgrade of nagios keeps installing an outdated check_postgres.pl (2.21) that is nog able to monitor posgressql databases >12. We are getting issues anytime we get an Nagiosxi update when it replaces a working version (2.26) with yhis old one(2.21).
I would say , remove it from installer or fix it. :evil:
DoubleDoubleA
Post by DoubleDoubleA »
Hi @CBoekhuis,
Thanks for the follow up. We totally dropped this issue, and I apologize. I have a staffer on it now, we're targeting to have this updated for the May XI release.
Aaron
Post Reply
