What do you use to graph perfdata?
Post Reply
mdcyntst2
Post by mdcyntst2 »
I've been beating my head against the wall for days now trying to find a working solution for graphing perfdata. AI summed up something for me at one point stating the NagiosXI has a proprietary builtin solution, but the community edition has not standardized on a solution.
It seemed like a simple thing (in fact in the past it was). Nagios->perfdata->rrd->rrd Graph tool. In the past I've used nagiosgraph and cacti as tools, but Nagios 4 seems to impede things, as well as those old school rrd tools are deprecated and no longer support current versions of OS and perl (v8 specifically)
So my first ask is how do you collect your perfdata(nagios4) and graph it
Thanks in advance
jmichaelson
Re: What do you use to graph perfdata?
Post by jmichaelson »
You mentioned using Nagios XI. have you considered using theCSP Edition
https://www.nagios.org/?utm_campaign=csp&utm_source=nagioscore&utm_medium=splash_button&utm_content=4.5.10#csp-section-home
? Its limited to 10 hosts. but if that's sufficient for you it may be helpful.
-Jason
jdmsilbvs
Post by jdmsilbvs »
Aliyaa
Post by Aliyaa »
It feels like a genuine problem-solving thread, with clear suggestions that could actually help others facing the same issue. Shala Darpan
-SN
Post by -SN »
I have an experimental project that I've been working on for Core.
It combines Core + Prometheus to give you time-series performance data hence the name, NagProm.
https://github.com/SNapier/nagprom
Feel free to check it out, make it better, whatevs it's OSS
--SN
Post Reply
