I have tried to perform upgrade of the Nagios XI to the latest version 2024R2.2.1 however it shows success but the version wasn't upgraded to the latest & scheduled backup gives me "Error: This component requires the pecl ssh2 module. You must run install.sh in /usr/local/nagiosxi/html/includes/components/scheduledbackups as root to use this component". I am trying to perform this i am getting below.
nagios@AZGDEPNAGIOSXI02:/usr/local/nagiosxi/html/includes/components/scheduledbackups$ sudo install.sh
sudo: install.sh: command not found
Regards,
Sandip Khedekar
Scheduled Backup giving error after the Nagios Upgrade
Sandip2705
Re: Scheduled Backup giving error after the Nagios Upgrade
Hi Sandip,
I believe this has to do with how sudo executes commands combined with trying to include a path that isn't in your $PATH variable. I would recommend that you cd into the directory and then execute the install.sh script from within there. Let us know if you run into further issues with this.
Sandip2705
I have tried from the directory but issue remains same.
nagios@AZGDEPNAGIOSXI02:~$ cd /usr/local/nagiosxi/html/includes/components/scheduledbackups/
nagios@AZGDEPNAGIOSXI02:/usr/local/nagiosxi/html/includes/components/scheduledbackups$ ls
CHANGELOG.txt ajaxcalls.php images includes install.sh localbackups.php managebackups.php scheduledbackups.inc.php
Regards,
Sandip
Regards,
Sandip
nagios-dnelson
Try it with a dot and a slash, like this:
That should help with the "command not found" error.
sudo ./install.sh-
Sandip2705
Apologies for the delay in response. Please close this as issue has been resolved.
Regards,
Sandip
Regards,
Sandip
DoubleDoubleA
