We have a RedHat 8 server running 2024R2.2 (and php 8.1) in a secure environment which needs offline upgrades.
I have just tried upgrading to 2024R2.2.1, it seemed successful but does not show in the frontend or in /usr/local/nagiosxi/var/xiversion
I tried following the instructions on viewtopic.php?p=362002&hilit=upgrade+no ... fa#p362002 , it went through and seemed to try installing, no visible errors in the output, but still change in the version.
It's not an issue with the 'upgrade' script and the PHP 7 rpm's, as I've excluded the rpm and removed them from the offline-nagiosxi directory, this has worked several times before.
Offline upgrade from 2024R2.2 to 2024R2.2.1 issue
Re: Offline upgrade from 2024R2.2 to 2024R2.2.1 issue
Hi @scookpfs,
I'm sorry to hear you're running into issues with offline upgrades. I believe opening a support case is the best way to fix the problems you're seeing. You can do that here.
SprunkiRetake
I ran into a similar issue during an offline upgrade — the script looked successful, but the version didn't update in the frontend or xiversion file.
Sprunki Retake Good tunes will help people relax!
What worked for me was manually checking the contents of /usr/local/nagiosxi/tmp after the upgrade attempt. Sometimes the unpacked files don’t fully overwrite, especially if permissions are weird or SELinux is being picky. I had to chown a few things and rerun parts of the install manually.
zross
Nice. Thank you.fondicky wrote: ↑Thu Oct 02, 2025 11:41 pm What worked for me was manually checking the contents of /usr/local/nagiosxi/tmp after the upgrade attempt. Sometimes the unpacked files don’t fully overwrite, especially if permissions are weird or SELinux is being picky. I had to chown a few things and rerun parts of the install manually.
