PHP 8.4 Syntax Issue - gauges.inc.php
Post Reply
Alongaks
Post by Alongaks »
As of a recent update of Nagios XI to v2024.2.2.1 then a PHP 8.4 upgrade in the Nagios XI host, any service performance graphs would sit and never render. They get a constant spinning wheel.
I fixed the issue but it then returned in Nagios XI 2026R1.
The PHP error logs revealed the following:
Uncaught ValueError: str_getcsv(): Argument #3 ($enclosure) must be a single character in /usr/local/nagiosxi/html/includes/dashlets/gauges/gauges.inc.php:351
Doing a little digging it turned out to be a syntax correction in the script to get the performance graphs on services to render again.
Changed the ' to a single quote ' and the perf graphs were then able to load.
$perfdata_datasources = str_getcsv($status['performance_data'], " ", "'");
    foreach ($perfdata_datasources as $perfdata_datasource) {
        $perfdata_s = explode('=', $perfdata_datasource);
        $perfdata_name = trim(str_replace("'", "", $perfdata_s[0]));
TO
This is likely a PHP 8.4 change/update to former syntax.
After making this change in the code, restarting PHP and nagios it was back to normal.
Can this be added to the next round of updates?
lgute
Re: PHP 8.4 Syntax Issue - gauges.inc.php
Post by lgute »
Hi @Alongaks,
Thanks for reaching out. An issue in our bug tracking system. While I cannot guarantee it will make it in the next release, when it does it will appear in the CHANGELOG as [GL:XI#2176].
-Laura
DoubleDoubleA
Post by DoubleDoubleA »
Hi @Alongaks,
How well does the rest of the application work for you in php8.4? In testing this change internally we're seeing other issues on 8.4. What distro are you on? Did you update to 8.4 before or after XI was installed?
Thanks!
Aaron
Product Development Manager
ariellrut
Post by ariellrut »
Your diagnosis is spot-on. PHP 8.4 introduced stricter validation for functions like
str_getcsv()
, particularly requiring the
$enclosure
parameter to be a single character. Previously, using something like
(which is an HTML entity) might have been tolerated or ignored, but PHP 8.4 enforces this rule strictly.
Your fix—replacing ' with ' in the $enclosure argument—aligns with PHP's requirements and restores proper functionality. It’s a good catch that this change is necessary for compatibility with PHP 8.4.
Krist
Post by Krist »
Since lgute confirmed this is tracked as [GL:XI#2176], is there any update on whether the official fix will make it into the next maintenance release of Nagios XI, or will it be held until the stability issues on PHP 8.4 are fully resolved?
null’s brawl
DoubleDoubleA
Hi @Krist,
In QA-ing that specific fix, we updated a couple of test machines to 8.4 as part of the QA process, and in that found some other parts of the interface that likely need attention for the 8.4 update. Which was why I jumped into the conversation yesterday, asking about distros and other experience with 8.4. So while we could release that fix, we're likely not out of the woods yet on the full scope of work required to support php 8.4.
Aaron
wardenr
Post by wardenr »
Krist wrote: Thu Oct 30, 2025 5:59 am Since lgute confirmed this is tracked as [GL:XI#2176], is there any update on whether the official fix will make it into the next maintenance release of Nagios XI, or will it be held until the stability issues on PHP 8.4 are fully resolved?
COC MOD APK
It fixes an issue with the Smart… (changelog entry truncated in the source), and it appears alongside other PHP-related fixes such as GL:XI#2168, which specifically addresses gauges not rendering with PHP 8.4.
lgute
Post by lgute »
Hi @Krist,
The fix for [GL:XI#2176] was released in XI 2026R1.01. Additional fixes will be released in 2026R1.1 and we will continue to work on supporting PHP 8.4.
-Laura
sedapow84
Post by sedapow84 »
Thanks for the detailed writeup and fix, Alongaks.
I can confirm this issue exists in 2026R1 as well. The `'` HTML entity is no longer accepted as a valid enclosure character in PHP 8.4's `str_getcsv()` — it requires a single character, so replacing it with a literal single quote `'` is the correct fix.
For anyone hitting this until an official patch lands, the workaround is in `gauges.inc.php` around line 351 — replace both instances of `'` with `'` as shown above, then restart PHP and Nagios.
Hopefully the Nagios team can roll this into the next release. Good catch. www.whatabigailsays.co.uk
lgute
Post by lgute »
The fix for this issue was included in 2026R1.0.1 - 2025.11.11. If you are still having issues after upgrading, please let us know.
-Laura
Post Reply
