Nagios performance
Post Reply
occ
Nagios performance
Post by occ »
We have a Nagios server (with 32 CPUs and 32 GB of RAM), running approximately 15,500 checks — 2,500 of which are passive checks received from another Nagios infrastructure.
The system is extremely slow when applying configuration changes, and the load check frequently triggers warnings. What optimizations can we implement to resolve these performance issues?
lgute
Re: Nagios performance
Post by lgute »
Hi @occ,
Thanks for reaching out. Is 32 the correct # of CPUs?
This document may give you a good starting point.
-Laura
kg2857
Post by kg2857 »
I'm just curious.
What does top say when activating changes?
How many hosts are there?
I'm also curious how the services are set up. Are they generic whenever possible (many hosts attached to the same service), or unique for each host. For example a CPU usage check can be unique for each host or many hosts attached to the same service.
Maybe run the reconfigure script and see which parts are slow.
occ
Post by occ »
Yes 32.
and yes they are generic
also sometimes when i open a service i get the page "object doesn't exixt"
lgute
Post by lgute »
Hi @occ,
If you need to resolve this issue quickly I would recommend opening a ticket with our support department as they have experience with this type of issue. You can access the Customer Support Portal at https://support.nagios.com/ and open a ticket.
-Laura
Post Reply
