HI,
I am not sure, should pnp4nagios also work for Cisco memory and load?
Using plugins check_snmp_cisco_memutil and check_snmp_cisco_loadavg.
I was pretty sure that I've already seen this in pnp4nagios.
But now I'm only getting errors *.XML not found.
On the other hand, pnp4nagios for pings is still working and also e.g. different checks for servers showing graphs with pnp4nagios.
Maybe I'm wrong and I've never got pnp4nagios graphs for the load and memory of Cisco switches?
Thanks.
pnp4nagios Cisco switch memory and load?
kuchenmann
Re: pnp4nagios Cisco switch memory and load?
Ok, I found a solution for these two plugins.
Because they are not binary, it's possible to edit them.
Adding pipe and value to the output, then the perfdata files are created for pnp4nagios.
if ($status == 0){
# I've added |CPU=$cpu5min to get data for pnp4nagios.
print "Status is OK - $returnstring\n|CPU=$cpu5min";
if ($status == 0){
# I've added |MEMUSED=$mempcused to get data for pnp4nagios.
print "Status is OK - $returnstring\n|MEMUSED=$mempcused";
if ($status == 0){
if ($status == 0){
