PDF file not attached in schedule report in 2026R1
Post Reply
speynaud
Post by speynaud »
from update of last NagiosXI 2026R1 my scheduled report sent by email doesn't include report on PDF attached in message.
I check the option to include PDF in mail but it is not attached.
Does it a known issue of 2026R1 or it's an issue in my conf?
Thank you
jsimon
Re: PDF file not attached in schedule report in 2026R1
Post by jsimon »
Hi Speynaud,
I can confirm I was able to generate reports on a local test server running version 2026R1, and don't believe there are any known issues with reports on this version. Can you take a look at this file on your XI server?
/usr/local/nagiosxi/var/chromium_report.log
This should give us a good idea what's going wrong.
speynaud
Post by speynaud »
Thank you so much for your message, it was very helpfull for me.
In log file before 2026R1 update all were OK I saw nagios script used "google-chrome-stable" to generate PDF file but after update I saw in log :
/bin/bash: line 1: google-chrome-stable: command not found
Thanks to IA I fix it with a symbolic link :
ln -s /usr/bin/chromium /usr/bin/google-chrome-stable
It seems day where I updated Nagios XI in my RHEL 9.6 "google-chrome-stable" was deleted and know I should use "chromium"
I hope this topis will be helpfull for another people ;)
Thank you very much again for your help
Post Reply
