Problème updating from 2024R1.4.1 to 2026R1
Post Reply
steph007
Post by steph007 »
This is part of the problem I have when I update from the command line. Sorry, I had to cut most of the output because otherwise the forum was blocking my input!
Checking install type...
Install type: source
Installation check passed.
Are you sure you want to continue? [y/N] y
Proceeding with upgrade...
Nagios XI Upgrade Log
DATE: Mon Oct 20 13:42:18 EDT 2025
DISTRO INFO:
RedHatEnterpriseServer
8.10
x86_64
Nagios Core 4.5.3
Last Modified: 2024-06-11
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 25 services.
Checked 4 hosts.
Checked 1 host groups.
Checked 1 service groups.
Checked 9 contacts.
Checked 4 contact groups.
Checked 193 commands.
Checked 18 time periods.
Checked 0 host escalations.
Checked 4 hosts
Checked 0 host dependencies
Checked 18 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Updating Subscription Management repositories.
/usr/lib/python3.6/site-packages/OpenSSL/crypto.py:12: CryptographyDeprecationWarning: Python 3.6 is no longer supported by the Python core team. Therefore, support for it is deprecated in cryptography. The next release of cryptography will remove support for Python 3.6.
from cryptography import x509
cdietsch
Re: Problème updating from 2024R1.4.1 to 2026R1
Post by cdietsch »
Hello steph007,
Have you tried installing a newer version of python3? I think all you should need to run is something like:
sudo dnf install python3.12
Then try to rerun the upgrade script. Good luck!
Cheers,
- Cole
steph007
Post by steph007 »
Look good now.
I received this during the update, but it does not look to have impact on Nagios:
[MIRROR] libgearman-1.1.19.1-1.el8.x86_64.rpm: Curl error (60): Peer certificate cannot be authenticated with given CA certificates for https://muug.ca/mirror/fedora-epel/8/Ev ... x86_64.rpm [SSL certificate problem: self signed certificate in certificate chain]
[MIRROR] gearmand-1.1.19.1-1.el8.x86_64.rpm: Curl error (60): Peer certificate cannot be authenticated with given CA certificates for https://muug.ca/mirror/fedora-epel/8/Ev ... x86_64.rpm [SSL certificate problem: self signed certificate in certificate chain]
[MIRROR] hiredis-0.13.3-13.el8.x86_64.rpm: Curl error (60): Peer certificate cannot be authenticated with given CA certificates for https://muug.ca/mirror/fedora-epel/8/Ev ... x86_64.rpm [SSL certificate problem: self signed certificate in certificate chain]
... and more
steph007
Post by steph007 »
look like all work well. In my test environment and my prod.
Thanks, you can close this.
Post Reply
