Err:6 https://repo.nagios.com/deb/focal InRelease The following signatures couldn't be verified because the public
Post Reply
ssubr
Post by ssubr »
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 471D5F4645ECF0AD
Fetched 16.6 kB in 3s (5,249 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.nagios.com/deb/focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 471D5F4645ECF0AD
W: Failed to fetch https://repo.nagios.com/deb/focal/InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 471D5F4645ECF0AD
W: Some index files failed to download. They have been ignored, or old ones used instead.
root@detaaadrpdev02:/var/www/html/marketingselfserve.onemagnify.com/vendor/drush/drush# timed out waiting for input: auto-logout
bgelhaye
Re: Err:6 https://repo.nagios.com/deb/focal InRelease The following signatures couldn't be verified because the publi
Post by bgelhaye »
Could you please try re-downloading the key and then running apt-get update? Instructions on downloading they key can be found on https://repo.nagios.com once you select what flavor of Linux you're using.
- Brandon Gelhaye
vouchphoto
Post by vouchphoto »
ssubr wrote: Mon Oct 27, 2025 12:42 pm Err:6 https://repo.nagios.com/deb/focal InRelease
It seems like there's an issue with the public key for the repository. Have you tried updating the key with the command sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 471D5F4645ECF0AD?
Post Reply
