Issue while adding new host for monitoring
Post Reply
chinmaypatil
Post by chinmaypatil »
I am configuring Nagios Core Version 4.5.0 and nagios plugin version 2.4.8 on Ubuntu 24.04 LTS and have everything set properly. Now when I add a new machine to monitor like deb12.cfg, it doesn't compile when added the define service section in the file. It throws an error as below:
sudo /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Error: Service check command './check_ncpa.py -t NagiosCore123 -M system/agent_version' specified in service 'NCPA Agent Version' for host 'deb12' not defined anywhere!
Checked 9 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 25 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 2 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 1
Now I am not sure why its happening. I did installed it 2-3 months back using same version and it did worked but now its not.
If need any more info then please let me know I will share it ASAP.
Thank You.
MaterazziSan
Re: Issue while adding new host for monitoring
Post by MaterazziSan »
I would check:
  • Host "deb12" definition.
  • Service definition.
  • Command definition.
Can you share those?
Best regards
Post Reply
