a couple of comments on the new 2024R1.3.6 update
Post Reply
CBoekhuis
Post by CBoekhuis »
whilst applying the new 2024R1.3.6 update on our test cluster I found a few "things" that might need a little review.
The update is normally +/-220MB but now 1.5GB. Apparently there's also a 1GB opensearch tar file included which is part of the 2026 release? Should that be in this update?
I could run the upgrade from 2024R1.3.5 to 2024R1.3.6, but when I re-enabled the shard allocation nothing happened. It seems that there's a typo in the upgrade guide:
In the guide: curl -XPUT localhost:9200/_cluster/settings -d '{"transient":{"cluster- .routing.allocation.enable":"all"}}'
but it should be: curl -XPUT localhost:9200/_cluster/settings -d '{"transient":{"cluster.routing.allocation.enable":"all"}}'
Cheers...Hans
DoubleDoubleA
Re: a couple of comments on the new 2024R1.3.6 update
Post by DoubleDoubleA »
Hi Hans,
Thanks for the information.
Apologies for abusing your disk space, the opensearch tarball did not belong and the build team corrected their process.
I've passed the documentation fix along to the doc team as well.
Thanks again,
Aaron
jmichaelson
Post by jmichaelson »
Thanks! I'll have the doc team have a look at it.
-Jason
jmichaelson
Is there another typo? Our doc team indicates that this has been remedied.
-Jason
CBoekhuis
Post by CBoekhuis »
No, a spammer is inserting links in the reply. Very annoying....
DoubleDoubleA
Sorry I missed that link spam, I just cleaned it up. It is a constant battle.
DoubleDoubleA
Post Reply
